Mach1 guys...Free mod...
I heard that if you unbolt your Shaker and put a bigger washer under there that it will raise your shaker a little bit, give you better air flow, add a few ponies, and give a littel better gas milage....
anyone ever heard of this?
RE: Mach1 guys...Free mod...
I'm sure it will give you a little bit better flow. However I very strongly doubt its actually going to give you any horsepower. If it does its probably abotu 1/4-1/2 a pony. How much could you REALLY benefit from your shaker being another 1/4 inch up in the air??? Go ahead and try it tho, tell us if it works!
1. its not really a free mod... someone had to buy a washer/s or spacer at some point.. so there was money spent.
2. you might get a little bit more air to go into the scoop, but then you are messing with the aerodymanics and causing drag... so in turn even if you got 1/2 a pony you might really be losing 1-1 1/2 from the drag you created.
Just my .02 cents.
Just my .02 cents.
ORIGINAL: MustangMafia
ORIGINAL: Emann0007
1/4 inch??? That's a thick *** washer
I doubt the drag will be affected in any measureable way.
So to recap: it could give you a HP increase, but not even close to something that would be noticed. It would incrase your aerodynamic drag, but not even close to enough to be noticed. BUT, it might look a little bit cooler and that might be worth the cost of a thick *** washer (lol).
