How do you double clutch?
#24
Guest
Posts: n/a
Originally Posted by GT99GT
what is is considered when you clutch , jam it into the next gear and gas it.... that isnt powershifting... is it bad for the tranny?
Powershifting like thathurts the synchros and the teeth on the gearsmore than it does anything else. </P>
#26
Guest
Posts: n/a
Originally Posted by whitelightning
Powershifting is hard on your car, true but in a tight race it will lower your ET!!!
If you don't blowyour transmission whilest you're slamming gears. <IMG src=smileys/smiley3.gif border="0"></P>
#27
The fast way to shift with out power shifting come sdown to timing. What I do is when I want to shift hard and fast.As I start to push in the clutch and let off the gas I am already taking the car out of gear as I hit neutral the clutch is full in gas is full off and I start to put it into the next gear as I let the clutch out. When The clutch is fully out I should have just gotten into gear and stomping on the peddle. This video shows what it looks like minus the foot work. Works really well saves the tranny some beatings and makes two gear burnoutsnice. I have a couple two gear pulls with less then a 1ft between marks. </P>
Interior Shift 3 gear</P>
#28
#30
Originally Posted by vfast
that's what make racing fun the UNKNOWNS!
