Finally Figured out my Exhaust set up... But still need some help PLZ!
RE: Finally Figured out my Exhaust set up... But still need some help PLZ!
alright Wick001, here is the scoop. you have the flomasters ready to go, right? if you know a person that can weld all of this for you , cool, but be sure he has no problem cutting off the stock cats. Before you do all of that , order some mil eliminitors, you will need those for the rear o2 sensors, turns off he check engine light. you do not need any extensions for sensors, those are only needed for the front 02 sensors. all said and done, the cats will be cut off, he will replace those with about 3 feet of straight pipe (2 1/4, stock pipe), plug in the mil eliminitors and you are done, car will be LOUD!!! you can order the mil eliminitors almost anywhere, try uprproducts.com. Enjoy the sound!!!
Why not just save up till you have enough to get the actual catback, rather than weld-in mufflers?
You won't get as good of gains with just the mufflers, and sometime down the road you'll probably end up switching to the real deal anyway.
91StangOwner
08-20-2015 11:34 PM
