Finally Figured out my Exhaust set up... But still need some help PLZ!
Well, i think i finally figured out what im going to do, But i need your guys' help,
I going the cost effective route, i cant deny it, i love the way the flowmasters sound... The most aggresive sounding ones are the 40's right?
Then i want to install somthing else, but i really have no idea what an X Pipe, H pipe, Off Road or any of that means... I want the sound of the flows, but LOUDER...
What do you suggest i want to keep it under $400, so the flows will cost me about $100 to $120/ Then what do i need, How do i install it? weld ? Do i need other connectors? Sensors? extensions?
Thanks guys, This forum rules...
RE: Finally Figured out my Exhaust set up... But still need some help PLZ!
I would reccomend an H pipe with chambered mufflers (which flowmasters are). If you want to get it as loud as possible go with an Off/Road H pipe. Off-Road means it has no catalytic converters, which filter out pollutants. Off/Road Pipes are not technically legal to run because of emissions. If you live in an area with emissions checks, go with a catted midpipe. And the difference between an H and an X pipe is pretty minimal as far as horsepower gains go. It is usually best to go with whatever will sound the best because the difference between an X and an h will only be a HP or 2.
Are you installing the flowmaster yourself? If not, I'd suggest just having them do it for your while they are under there anyway. They will probably charge you about 50 bucks to install the midpipe. And what year is your mustang?
i have the flomasters with o/r h pipe and it sounds great. if really want to save money and know some one who has a welder, cut off the stock cats, buy the mil eliminitors for the rear o2 sensors and bam, a cheap o/r h pipe has been created.
I have a 2003 GT, I heard one guy say somthing about extensions for sensors? and 02 simulators?
Whats a good midpipe? and will that be able to just connect right to the mufflers?
I would definitely try to do it yourself if you have the place to do it. Installing both the catback and the midpipe is very simple. It will also give you a crash course on your exhaust system, being able to see how everything is routed and what everything does/where it hooks up. As simple as it is, it's still good to know if your unaware.
Isn't the replacement midpipe usually just a little bit larger in diameter? I think getting a new midpipe would still be the best choice instead of doing a frankenstein to the stock pipe.
ORIGINAL: Quickshift_02GT
I think he wanted to do weld-in flowmasters tho.....
Hmm...
Would the cost of getting the weld-in Flowmasters plus installation, plus installation of the midpipe(assuming he purchases one) be lower than the cost of just the midpipe/full catback when he installs it himself?
ORIGINAL: Like778
What are "mil eliminitors for the rear o2 sensors"
Can some one tell me exactly what i will need?
