what should i do with 2k???
RE: what should i do with 2k???
If you have any plans to get a KB in the future, you probably shouldn't waste any money on a new pulley for the current blower. A Throttle Body, exhaust and Cold Air Intake can each give you more power and compliment a Kenne Bell if you go that route in the future. A few suspension mods will make a dramatic difference to the IRS, and a short shifter will make shifting feel less sloppy. I recommend calling up Maximum Motorsports for some suspension mods and MGW for a shifter.
I highly recommend the MGW Shifter too. Good choice Fallstar [8D]
For traction, I suggest you get the Cobra IRS brace kit. It's cheap and it'll save your rear end from the damage wheel hopping does.
ORIGINAL: yellowcobra
Hi there guys i have an 04 cobra I have 2k right now to spend what are your suggestions. Except for cat-back exhaust cause i'm doing that for sure.
