I've decided on a combo
After doing research and talking to many people about which heads/intake/cam setup i should go with this is what i have decided to go with:
MPH stage 2.5 heads
Typhoon Intake (coming soon) (ported and polished)
VT stage 1 cams
I think this setup should really give my current non-PI 97 gt a good jump...any feedback or opinions??
MPH stage 2.5 heads
VT stage 1 cams
RE: I've decided on a combo
i heard those are pretty good as well....but these are supposed to be the best flowing heads on the market right now
http://modularpowerhouse.com/product...9bf9ad246ce6f8
Those are clearly PI heads based on the rectangulr intake ports so you'll NEED to get a new intake manifold if you go with those heads.
Good luck with the setup. Be sure to post some before/after numbers.
ORIGINAL: 97stanger
MPH stage 2.5 heads
VT stage 1 cams
MPH stage 2.5 heads
VT stage 1 cams
Would I be fine doing MPH stage 2.5 heads and custom grind cams from MPH without changing my intake at all?? It is a stock non-PI, but i can't see spending close to $1000 for an intake to barely gain anything. Would I be okay doing this setup and saving myself some money??
the mph heads are pi ones so you are pretty much doing a pi swap therefore you'd need all the gaskets and brackets that go along with a pi swap plus a pi intake manifold. go ahead and get the stage 2 cams cause you'll be making more power and usually dont cost more than stage 1s
ORIGINAL: M1ke
I think your best bet would be to either get the heads/cams installed with a PI (stock) intake, or go whole hog with a forged bottom end, the above, and a aftermarket intake.
I could be wrong, so check with code for sure, but I don't think a aftermarket intake is gonna do much good for you unless you do the shortblock, because once again you will not be able to rev high enough to take advantage of the gains of the intake.
Whatever you do, get rid of the stock nonpi intake. It sucks, and you have to have adapters to match it to the PI heads.
