new rear end...
RE: new rear end...
you are also going to need the install kit which includes the bearings and gaskets. For the changing of the axle you are going to need new studs, and while you are getting stuff get a new diff cover. You don't need a new differential cover but it will look nice with a nice cover on there. Good luck on the install and remember to break in those gears before jumping on them. What kind of gears are you getting? 4.10's, 3.73's,3.55's, or stock?
RE: new rear end...
ORIGINAL: wwmost
how the hell did they forget to put the plug back in
He said he had a guy forget to put a plug back in a transmission. When the whole thing went down and they had to pay for it, he asked the guy why. His answer?
"It was really ****ing hot, and I burned my hand twice, and then just said screw it".
RE: new rear end...
ORIGINAL: 2000GT4.6
A guy I know at work used to be a supervisor at a quick change place.
ORIGINAL: wwmost
LOL.. What an a** clown.
RE: new rear end...
ORIGINAL: 2000GT4.6
ORIGINAL: wwmost
RE: new rear end...
ORIGINAL: code3GT
Eaton posi, no question.
I've heard that the torque bias is a bit high and some folks end up spinning the inside wheel on occassion. In anycase, the vast majority of people who go with the Eaton are happy and almost everyone will recommend it over an Auburn (that has tried both). A T-lok is an economical choice but they granade at the drag strip more often than the Eaton, even if you get a T-lok with carbon-fiber clutch packs. They may also need to get rebuilt more often than the Eaton.
At the same time, people have had their share of issues with the Eaton just like any other diff:
Help Blown Eaton rear How to remove axels
broken eaton posi and mess up gears costing me more money
EATON POSI Guys, Need Advice
Rearend goes Boom! (several pictures)
RE: new rear end...
Update as of 2/9/06
I was not able to upgrade the rear end as much as I would have liked, but I did get some new 3.73's out of this...Also had the new bearings, shims, etc installed while it was open....My concern now is that I still have a whine somewhat....Anyone know what other components might have been damaged...I had everything checked out and was told the only damage was done to the rng and pinion...
RE: new rear end...
I like them alot...its perfect for me...I know many would have said should got 4.10's blah blah...but everyone likes something different....For me ths is good, more pull, especially in second gear...And with all the new suspension I got I am stoked...My only concern now is this whine I still have...Anybody?
