Gears whats the dif?
RE: Gears whats the dif?
ORIGINAL: Niffty little V8
Ok All I want to know is what my 1998 gt gears are if they are stock
My '98 GT vert auto has an axle code of "Z" which are 3.08's. I verified this by checking my rpm's at 70 mph (right around 2,000). The maximum stock gear you will find in any Mustang before '05 is 3.27's which were stock from '99 through '04. '05 & '06's have 3.55 stock gears. I am talking regular GT here, not special models or Cobras. In the '80's and '90's models, Ford bounced around alot. You'll have to check your axle (AX) code on your door jam and compare it to a code chart. Or, just chime back into these forums with what code you found and someone will let you know what axle ratio that equals.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
