FACTORY H-PIPE
RE: FACTORY H-PIPE
i got an o/r x pipe to the flowmaster....before the x it looks to be the stock mid pipe, has two cats that i can see. ..plus the difference in the pipe condition( clean or rusted) is a good indicator if it stock or after market....but im really not sure
RE: FACTORY H-PIPE
the 98GT obviously comes with a FACTORY H-pipe. That's why it's called FACTORY, it was put their by the FACTORY.
The stock H-pipe will have 4-6cats on it and will be 2 1/4" in diameter.
Most aftermarket midpipes will have 2 or 0 cats on it, and will be 2.5" in diameter.
Soooooo.... if you don't see any cats on your midpipe than it's not the stock or "factory" midipe.
RE: FACTORY H-PIPE
ORIGINAL: rstylianou
Yall are killing me, so a 98gt does come with a factory h-pipe, so whats wrong with it, why would i have to buy an aftermarket one.
edit: quickshift you beat me by 8 seconds [:@]
RE: FACTORY H-PIPE
Are you listeing to me i cut off all of the cats thats 6 of them so you really thing iam going to make alot more hp because the factory is 2 1/4 and the aftermarket is 2 1\2
RE: FACTORY H-PIPE
rstylianou, don't make this harder than it is. To make horsepower our cars need to breathe. Cutting off the cats on a 2 1/4" factory h pipe probably gave you a few more hp than stock but not as much as a 2 1/2" aftermarket catless h or x pipe. Although you have no cats, you still have a small diameter in mid pipe and exhaust which is restrictive (especially where you welded in the flow tubes after removing 6 cats). If you want more hp, go with 2 1/2" h or x pipe and 2 1/2" cat back exhaust.
Opening up the exhaust is not always the magic pill that it is put up to be. You lose low end torque when you open up the exhaust on a stock car (especially 2 valves which already suffer in the low end torque dept). Lots of horsepower is nice but torque gets you off the line. Look at your future goals and determine the direction you want to take.
