2003 mustang gt brake problem
when i hit the brakes they make a creeking noise. anyone had this problem?? pads are good sure something just need greasing. it makes the the noise wether i'm moving or not.
RE: 2003 mustang gt brake problem
Do you drive the car every day or is there time where it sits for a day or so?
What do you mean by creeking? Like the pistons are getting stuck moving or something like that?
drive it everyday it does it rather it's sits for a while or not. pistons can't be the problem because it stops really really well. just the creeking noise is kind of embarrasing is all. like put your foot on it it's like creeek as you push it then creeeeek as you get your foot off it. it has to be somewhere in the linkage is all i can think.
Is it when you slow to a stop? Or at all speeds?
Stock rotors are CRAP. Check your rotors...they are famous for warping.
happens wether i'm moving or not. even when parked it creeeeks making a creeking noise kind of like a squeeky bed.
So it happens when you engaged the brake pedal? Whether you move or not?
it could be the suspension traveling and binding, i had a popping noise when i went up steep driveways and ford fixed it
Could also be the master cylinder...
