Midpipe Install?
Midpipe Install?
So unlike when I installed my catback, I am gonna not be a biotch and install the midpipe myself. I didnt do the catback myself because I didnt have/want to buy jackstands or whatever I would need to get the car off the ground. So, what do I need to get the car off the ground enough to comfortably be able to install this thing (I'm a pretty big guy)? Will normal jackstands give me enough room to be able to do this? If anybody could walk me through this and give me a list of the things I will need, it would be greatly appreciated. THANKS!
RE: Midpipe Install?
I installed mine by using a set of ramps. It gave me plenty of clearance to do the dirty work.
There really isn't any tricks to getting it done. Jack it up or put it on ramps. Disconnect the front/rear sensors, unbolt rear flanges, unbolt front flanges from headers, lower from car.
The only issues I ran into was trying to unbolt the header flanges. I couldn't get my hand up in the drivers side very easy. Plus finding the connectors to unplug the sensors was a pain in the ***, till I found the exact location of them. Again, the drivers side was a pain in the *** to disconnect.
Other than that, easy as hell.
I only ran into one problem, I believe it's on the passenger side exhaust manifold. There is a crush sleeve and it was a bitch to keep it lined up. I put mine one twice and had a bad leak. Finally, I used scotch tape to attach it to the mid-pipe. Just a little help, I know it drove me crazy.
With jackstands, air tools, and a torch, it shouldn't be a tough job at all. I would suggest useing a torch to heat up the manifold studs, I did not when I did my 96 and I snapped one. It can be done without air tools as well, but that just adds to the work.
Depends how much **** you are willing to put up with. Like I said, if you have a set of air tools and a torch you should be able to do it by yourself. I tend to make it a rule to not let shops touch my car(bad experiences). So I will try to do everything I possibly can by myself.
