Quad shocks...
Quad shocks...
Are they necessary? I have Granatelli Motorsport upper and lower CA's and I hear that with CA's the quad shocks are no longer necessary. I was looking at my new 275 BFG DR's, and I don't think they will fit in the fenderwell with the quad shocks inplace. The question here is, is it okay/safe to remove the quadshocks, and how if at all will it affect my cars driveability. I noticed while reading in MM&FF that when they tested the new GT in "stock" form, they removed the quad shocks & front sway bar, so I'm assuming it is safe, but I don't know how it will affect my cars daily driving characteritics if at all. Thanks guys!
RE: Quad shocks...
ORIGINAL: Emann0007
With aftermarket lower control arms you will be okay.. It will still fit even with the 275's in there. I removed mine because they were rubbing one of my 315's under hard brakeing and right turns.
RE: Quad shocks...
ORIGINAL: Emann0007
thanks. Will the car feel any different?
RE: Quad shocks...
ORIGINAL: Emann0007
RE: Quad shocks...
Does removing the quad shocks for Granatelli CA's have the same affects as the Maximum Motorsport CA's. In other words, are they still not needed?
Also, what are your opinions on the quality of the Granatelli CA's compared to Maximum Motorsports? There is a HUGE price difference. I was planning on the MM versions.
RE: Quad shocks...
ORIGINAL: Quickshift_02GT
MM make GREAT STUFF. I have had no complaints with the GMS's. MM's use spherical bushings. My opinion is GMS' will work well on most applications. The MM's will probably be better suited for BIG HP applications.
RE: Quad shocks...
I think with any aftermarket lower control arms, you can remove the quad shocks.
