please help oxygen sensor signal wire color
RE: please help oxygen sensor signal wire color
yeah no **** man but its go to be one of the wires and that wire is a signal wire just cant splice into one and hope it works...thanks for the help but if you dont know then dont comment.
Found this a while back (Air/Fuel Ratio – Oxygen Sensor Gauge Installation
Pin number 87 at PCM, red w/black stripe or Pin number 60, gray w/light blue stripe). That was from autometers site so i hope it helps.
you have two green wires a white wire and a black wire. I believe it is the black wire. these are directly from the drivers side oxygen sensor. I have a 99 gt and did this about 3 months ago. for the a/f ratio meter. I will look under my car tomorrow and tell you the for sure answer.
TfcCDR
09-14-2015 12:08 PM
