Header Job SUCKS! - Page 2 - MustangForums.com
Header Job SUCKS!
Old 02-13-2006, 11:13 PM
HaV
Default RE: Header Job SUCKS!
Lmao, I asked a friend if He would help me when I get around to buying a set of LT's.. his response "Only if the engine is already out of the car when I get there"
Shops are sooooo outrageous for the labor on headders for theses cars as well.. its just nuts what they want to charge.. they dont even look at the book in terms of hours, they just tell you up front you need to sign your first born and your soul over.
HaV is offline
Old 02-13-2006, 11:25 PM
2000GT4.6
ORIGINAL: 70 MACH I
I'm installing Headers on my '04 GT, the worst part of the job it seems, was removing the starter. If those bolt heads ever strip, I can see you'd definitely be F**ked! Other than that, the right side is worse than the left, you have to jack the engine to remove the bolts. I ordered carbon fiber sandwiched header gaskets from JEGS, and plan on purchasing a new set of manifold nuts from Ford, I'm going to stay with the stud setup, I like ford's morlok style anti-loosen nut. I do not want to go in there again for an exhaust leak. If anyone has experience with this job, or materials, give a shout. I was amazed at how small the factory manifolds are, nicely designed manifold, but tiny passages.
John
+1
Don't ya wish it was as easy as your 70?
2000GT4.6 is offline
Old 02-14-2006, 01:03 AM
04BlueGT
04BlueGT's Avatar
ORIGINAL: 70 MACH I
Ok, if you lower the K member, how can you be sure the K member is aligned properly with the chassis when you reinstall it? That, to me would create a huge disaster, meaning the front end being out of alignment with the rear. Besides, the most difficult bolts to get out are the top ones on the manifold, especially the right side, the left side has more room and actually isn't that bad to do. I spent the most time removing the starter and removing the RS manifold.
John
John has a good question there. I was looking at installing a tubular K-member, but this scares me a little. Is aligning the tracking a huge issue with the K-members? I think i read that you measure from the rear axle to get the spacing right front to rear, but what of the left and right (centering)? Anyone know?
04BlueGT is offline
Old 02-14-2006, 01:42 AM
czwalga00gt
ORIGINAL: 04BlueGT
ORIGINAL: 70 MACH I
John
It's no big deal... theres 8 bolts for the K-member; it cant be terribly off if all 8 bolts are connected properly. It is recommended that your front steering aligned at a shop after you're done. I was expecting to need it and it was going to pull... however it hasnt at all so i've been putting off the steering aligment. I still should probably get it done though.
czwalga00gt is offline
Old 02-14-2006, 01:47 AM
04BlueGT
04BlueGT's Avatar
Thanks, I feel better now. Good info.
04BlueGT is offline
Old 02-14-2006, 12:18 PM
Chopper
ORIGINAL: czwalga00gt
ORIGINAL: 04BlueGT
ORIGINAL: 70 MACH I
John
The techs said I didn't have to have an alignment but I sent it over to the machine anyway.It came out that they were right,there are alignment notches and you can remove the K-member without making a mess out of your front end.If i had known this I would have done the work myself.[:@]
Chopper is offline
Old 02-14-2006, 02:07 PM
Tim37
Tim37's Avatar
ORIGINAL: 70 MACH I
Chuckle, OK I guess I've done good. 4.5 hours and everything is on the floor. I'm waiting for parts before I re-install. And I will use TONS of anti-seize on everything to be sure.
John
thats about right for tearing the car down. i think a lot of poeple get discouraged when you can slap a set of headers on a 5.0 in a few hours and it takes a entire day for a 4.6
Tim37 is offline
Old 02-14-2006, 03:13 PM
70 MACH I
Ha, Ha, The long tube headers on the 351C in my mach are cake, 30 minutes. The windsor 351, even easier, The 428, good training for a 4.6, they sucked too. Back in the 70's we did one, Three of us, 48 beers and a saturday afternoon.
John
70 MACH I is offline
Old 02-14-2006, 03:23 PM
Dan04COBRA
Super Moderator
You are going to have to tighten those header bolts again anyways.
After a couple heat cycles they will loosen up. Even the lock washers will allow them to back up a touch.
Dan04COBRA is offline
Old 02-14-2006, 03:40 PM
boss281
i got my LTs Hpipe and catback installed at a speedshop for $388, but my steering column seems to be rubbing against something im thinking the headers, is this common or does anyone know how to fix it?
boss281 is offline
Quick Reply: Header Job SUCKS!
Featured Sponsors
