how much boost can stock 96 gt handle!?!?
Old 02-13-2006, 09:36 PM
striker_87
striker_87's Avatar
Default how much boost can stock 96 gt handle!?!?
I have a 96 gt and am planning on getting a turbo setup over the summer. My question is how much boost can my car handle safely? Is there anything I can do to bring up the amount of boost easily? Any info would really help thx.
striker_87 is offline
Old 02-13-2006, 10:06 PM
HaV
HaV's Avatar
Default RE: how much boost can stock 96 gt handle!?!?
everything I have read on the stock NPI GT's basicaly says stay below 8PSI if you want it to last very long. You could get so much more out of it if you forged the bottom end first. For the cost of a TT setup you could forge the bottom end and get a vortech slapped on. Honestly on a tubo setup I wouldnt mess with it without forged pistons/rods/crank, better heads, and suspension upgrades... There is sooo much potential in a turbo setup for major HP that it would be a shame to have to tone it down to the bare minimum it could push.
Are you planning a TT or single turbo setup? Are you looking at a kit or are you going to try to create your own with a pair of matched used turbo's?
HaV is offline
Old 02-14-2006, 03:12 AM
striker_87
striker_87's Avatar
Yeah I was planning on a tt kit that I found on http://www.turbochargedpower.com/96-04%20Mustang.htm and eventually I want to get the crate motor on there as well. It's able to handle 30 psi boost. I am hoping to make some good doe working in Desitn as a waiter this summer and was trying to think of the best way to spend it
Old 02-14-2006, 03:16 AM
Dark_Horse
Dark_Horse's Avatar
9PSI is fine on 91 gas and a good tune
Dark_Horse is offline
Old 02-14-2006, 01:17 PM
turbostang21
turbostang21's Avatar
it's all in the tune but 10psi should be fine. i am all for turbos...but i have to agree with Hav on this one. if you are buying a kit (not building it) it is so expensive that i see it as a waste vs a sc on a stock motor... but it is your money
turbostang21 is offline
Dragonus18
09-09-2015 01:21 AM
mungodrums
Suspension
09-07-2015 07:28 PM
M3hunter
09-05-2015 03:42 PM
09-01-2015 08:16 PM
Quick Reply: how much boost can stock 96 gt handle!?!?
