***PLEASE READ*** Brake Help!!
#33
RE: ***PLEASE READ*** Brake Help!!
ORIGINAL: ShadowDrake
Power steering pump provides the vacuum for the brake booster.
ORIGINAL: rbstang
what assists the brakes then??
ORIGINAL: Tim37
there is no vacume booster on his car.
ORIGINAL: rbstang
with the car off? because with the car off if you pump the brakes it should build up pressure like you said. If yours doesnt, sounds like your vacuum booster is leaking.
#34
One more thing, the brake fluid on the floor, it is possible that when you retracted your caliper pistons you cocked a cup seal on the master cylinder piston, also if the car has miles on it, as was mentioned earlier (and by the numerous bleedings) the seal in the master could be damaged due to over-extension (the piston seal goes past a worn or gummed up spot in the bore). I too had a low mile Chevy lumina do this to me, the key was low mile, the MC piston had taken a set, and bleeding the car destroyed it. (when bleeding, work the pedal only an inch or two when cycling it to avoid this) Whenever I change pads I bleed/flush the system WITHOUT EXCEPTION, brake fluid and coolant, are the two most overlooked fluids in a car. Brake fluid is hydroscopic, it attracts water ( by design) so if it becomes saturated, it starts rusting parts in the system. BTW, ABS units cost $800-$1500 1 quart of fluid, $6. No brainer, eh. In your case, if there is no air in the system, you need a master cylinder. I don't believe they are that bad in price, although I've never priced one on a stang. You just reminded me though, I need to bleed the wife's Bullitt, 2001 model year, 8,000 miles YEOOOW! That's an accident waiting to happen!
John
John
#35
ORIGINAL: beheivjer
It sounds like your rotors might have been turned past there limits and now the calipers are extened past what they should be causing a soft peddle. This means the rotors are too thin to work properly
I have put about 40 miles on the new pads and the peddle still goes to the floor... under normal driving conditions when I step on the brake peddle it has to be pushed down as far as the gas peddle if not further to come to a complete stop.. I know that isn’t right!!!
Now I was thinking about all this on my way home yesterday... I could understand the peddle feeling a little soft while coming to a stop b/c the new pads being a little slick or not broke in, but once I am stopped the peddle should not be able to be pushed to the floor... it should build up pressure and hold tight. So I think I will take the car to the other Ford dealership here in town and see what they say... its not owned by the same person so hopefully I wont get the run around.
Thanks for all the help guys... it gives me a little more confidence while facing the dealer!!
Ill keep you all updated to what happens.
Thanks again!
#36
Oh and also, they are not trying to save me money b/c i asked them to... i told them flat out.. i dont care what it is or what it costs.. i want it fixed.
Also i bought a extended warranty for the car that states clear as day as follows:
Non ABS and ABS systmes
All internally lubricated parts of the hydraulic system including the Master cylinder, vacume power assis booster and valve and so on... so its fully covered also... no reason why they should not replace the master cylinder.
I'm going back and telling them to REPLACE THE MASTER CYLINDER. END OF STORY!
#37
ORIGINAL: beheivjer
Brake fluid on the floor is honesly normal when doing a break job its form the oil change monkey's filling your master cylinder every time you get a oil change when you do a break job and compress your calipers all the fluid in the calipers has to go some where if you have a full resivoir it will spill out and hit the floor. usualy i don't add fluid when it gets low it means its about time to change either the fornt or reare pads.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
