transgo shift kit?
transgo shift kit?
I just won a transgo performance shift kit on ebay for 46.00$, not bad. just wondering if anyone on here has used there shift kit on there stang and what differences did you notice? are the shifts going to be alot harder then stock?also do these kits help with 1/4 mile times? i think the kit i won has something called gear command in it. thanks in advance.
RE: transgo shift kit?
Well if its anything like the shift kits for dsm's its going to be a pain in the @55. Pretty much all the kit comes with is different springs, and **** like that. It will help your tranny operate my efficiently, and shift quicker. Its more for biulding your tranny up rather than taking 1/4 times down.
no its not nessicary, but it will help with the biulding up of your tranny. Get the shift kit, tranny cooler, torque converter, and new gears... and you'll start slaying 5speeds.
ORIGINAL: wildazme
is a tranny cooler necessary with a shift kit?
ORIGINAL: wildazme
it really depends on your definition of "necessary". if you're gonna do it right, get the cooler. heat is the enemy of transmission fluid, it stops performing well when it gets hot.
ORIGINAL: Emann0007
you'll love it! Get a high tranny cooler while you are at it. You can get one off of Summit for about 60 bucks. Increase the life and efficiency of your tranny. DO IT!
