BBK underdrive pulley install?
Old 02-16-2006, 03:51 AM
sdsjr4
Default BBK underdrive pulley install?
Hey guys i need help on installing bbk alum. udp's. I bought used and they did not come with instructions but i pretty much know how to install but have a few questions? There's the three pieces them being alternator, and what's the other water pump pulley? and crank pulley right? I seen where someone posted they had to bolt bbk udp on the stock one is this true or do you just replace the whole pulley? Thanks for any help you can give!
sdsjr4 is offline
Old 02-16-2006, 03:56 AM
MTShambles
Default RE: BBK underdrive pulley install?
For BBK's you dont just swap out the crankshaft pulley. You reuse your stock crankshaft pulley and merge the BBK one with that one. Its whats called a piggyback style setup. If you notice with the Steedas and the BBK's, steeda's crankshaft pulley is MUCH larger and heavier, because its designed to be a full replacement.
As far as install goes, its just plain eaiser to use air tools to get the alternator pulley and the crankshaft pullies off. Otherwise, youll be fighting with rotating mass to get the damn nuts/bolts off. Remove your water pump pulley first, as it makes it eaiser to get the little bolts out, and it releases the tension on the belt for the other pullies. Make sure to take note on how the belt is run as well!
MTShambles is offline
Old 02-16-2006, 04:13 AM
code3GT
Mustang Nazi
code3GT's Avatar
Sell the piggy backs and buy some Steeda's...Just my 2 pennies.
code3GT is offline
Old 02-16-2006, 06:24 AM
MustangMafia
ORIGINAL: code3GT
You never give me any money.....
MustangMafia is offline
Old 02-16-2006, 09:26 AM
gt96stang
ORIGINAL: code3GT
gt96stang is offline
Luke9222
10-22-2015 11:55 PM
GimpyHSHS
09-18-2015 12:27 PM
Off Topic
22
09-11-2015 08:00 PM
mtgldr
09-10-2015 09:43 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: BBK underdrive pulley install?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
