how do i change to synthetic oil?
RE: First Oil Change
I worked in a repair facility for 2 years and have worked in a auto parts store for 5 years now and sell up to full syn about 65% of the time and maybe 3 have come back and had a leak problem. its going to leak no matter how fast or slow you switch to it. Thats just how it works it is either going to or its not
whats was the mileage on your car when you switched? see i couldnt afford to be 1 of those 3 but id really like to run synthetic to make my engine cleaner and last longer. if i dont ill just use Mobil clean high mileage
ORIGINAL: M1ke
So like i said it either going to leak or not
switching to a synthetic blend does nothing. every motor that ive seen blow up was on synthetic oil after running regular oil its whole life. unless synthetic oil is put in from the dealer its just gonna do a high mileage car harm
ORIGINAL: David_K
you could run a syn blend for this change and then swap to full syn
you see, when you run fossil oil in a car for that long, the engine seals get used to it. Switching directly to synthetic, a thinner oil (even tho it may be the same weight) gets into cracks better and is overall way better for your engine, prolonging tis life greatly, you might see minor leaking at first through the seals. I suggest going with a blended oil first, then switching to full synthetic next time.
ORIGINAL: David_K
yeah do you drive it like you would a gt
say my engine does leak from the synthetic, will the synthetic recondition the seals and will the leaking stop?
well mobils mobil clean 5000 is fossil, the 7500 is synth blend, and extended performance (15000) is full synth.
i could run the 7500 for the six months cause there's no way ill do 7500 first, then the full synth EP.
