intake removal
intake removal
OK I finally got my two friends over to install my denso iridium plugs and we were removing the intake and all but one hose came out. Idk what it is. It is a plastic type hose that is closes to the throttle body. It seems to be on a threaded thing lol. It is literally the only thing holding up the install. Also I bought a 10" socket extension so i dont have to remove the fuel rails right?
RE: intake removal
ORIGINAL: beheivjer
why are you pulling the intake are you pulling the tb there is only a couple of nuts to take off and 2 hoses grab a pair of pliers and twist back and forth until they losen up and pull apart
All of the intake hoses should just pull out....can you describe your problem a little better?
RE: intake removal
ORIGINAL: justingt
When I did my plugs, the socket kept getting stuck on the plugs and coming off of the extension, it was really annoying. Then I realized I should just tape it, lol.
RE: intake removal
ORIGINAL: justingt
yea we got the intake tube out and realized it would be way too hard to install these lol o well.
All you have to do is get the socket in there, and unscrew them. Pull them out, put some anti-sieze on the new ones,
screw them back in, put some silicone compound on the wire, and reattatch it. Cylinder 8 is the hardest because there is a lot of junk in the way, but overall its not bad.
I changed out my plugs and wires in a couple hours one night just chillin in my garage. Its really not that bad.
