DTC 5284 Oil Pressure Switch Failure
RE: DTC 5284 Oil Pressure Switch Failure
Ignore the reading you got in your cluster. You should never use the HEC diagnostics to begin with for anything other than a digital speedo or tach.
If you had a failure, you would have engine parts laying on the ground or you would have a CEL on.
ORIGINAL: Dan04COBRA
If you set it to show your actual mileage when you begin to start the procedure, it won't reset your trip.
I used to get pissed when I would lose my trip readings so I could calculate an average MPG after my 4.30 gear swap.
Also, when the car isnt running I get a 255 oil pressure reading (which is supposed to happen with the car not running), but when I start the car, it goes to 0, is that expected to happen?
ok the oil sender is only like 10 bucks its buy the filter.
don't buy a borg warner unit they don't fit. buy a motor craft. mine is going bad it doesn't read when its cold so i went to replace it got the borg warner (because its suposed to be better) and it was the worng one.
