Newbie Question...bear with me
RE: Newbie Question...bear with me
like 10-15 from the chip... a mear 5-8 from the CAI and why are u gunna do just x pipes? I would first go with a cat back system plus x pipes.. and u could see like 25-35 hp increase from those two combined
ORIGINAL: IownaMustangNow
You will get maybe 3 out of a CAI if it has a heat shield and is plastic. You will get MAYBE 10 if you get an O/R X pipe + straight-through catback. And from the tuner if it is a good custom tune with the timing all the way advanced you could hope for 8-10. So I'd say 20 at the most....
ORIGINAL: MustangMafia
Ummmm no..... I don't know what the crock of **** about 35HP from a catback + midpipe is....
Okay first you can only put one (1) x-pipe on your car. Try as you might, that second one just won't hook up right Secondly if you don't know what you are talking about then shhhhhh.... Your CAI will most likely net you less than 5RWHP. I dunno what kind of chip you have, but a diablo tune from what I keep seeing on here will net you less than 15RWHP. And a midpipe, while a great mod is restricted with your stock catback (due to its smaller diameter and stock mufflers) will net you probably less that 8RWHP
I would guess that you have added about 12-18RWHP. Please remember that the stock 265 is not actual RWHP.
ORIGINAL: Emann0007
jeebus man! You're about to lose your speaking privileges in the 4.6 room saying **** like that.
ORIGINAL: racer02GTstang
i thought bullits had more power like 270-275 stock? i thought that different manifold added more than 5hp to the car?
