help my tranny is whinning
02-21-2006, 09:18 PM
my transmission is whinning i was wondering if any knows what could cause this.........i have 4.11's doe's that make it do that .................????
02-21-2006, 09:24 PM
RE: help my tranny is whinning
is your tranny stick or auto? does the nose come from the tranny or the diff.
02-21-2006, 09:29 PM
it's a stick
02-21-2006, 09:30 PM
from the tranny i hear the noise from the rear end but i think that is just my low gears
02-21-2006, 09:31 PM
it might be your throwout bearing from your clucth if its coming from your transmission more than likely. my car does that too.[&o]
02-21-2006, 09:32 PM
really well i have some metal shavings also in my rear end........it seems like i'm starting to get alot of problems
02-21-2006, 10:09 PM
are you sure its coming from you tranny? if you have shavings in your rear its prob your gears. time for some 4.10's
02-21-2006, 10:14 PM
my tranny whines too in neutral idk why... i plan on getting new clutch install soon. hopefully that will take care of problem.
02-21-2006, 10:18 PM
rbstang if your tranny whines in neutrual does the whinning stop when you press on the clucth if so it you throwout bearing from your clutch
02-22-2006, 01:47 AM
my AUTO transmission whines a little bit when taking off (i assume it's the tranny). Is this normal? Some cars i've driven did it while other didn't, The car has only 31k miles.
