So I'm gonna burn my car to the ground...
RE: So I'm gonna burn my car to the ground...
ORIGINAL: Emann0007
Maybe you should suck my ***! I work and school full time you butnugget. I had to take off work and skip class just to go last night. I don't have a lot of time...
ORIGINAL: Dan04COBRA
Lame, does your car still feel like it's bogging today?
Possibly...does the DR set weigh more then your street set? If so it could be due to that...and if you dont have a stall converter to take advantage of the extra meat you could just be hurting your time out of the hole? I'm just speculating, hope it helps.
ORIGINAL: tripsevn7
ethan did you install your shift kit yet? what rpm did you launch at brother?
ORIGINAL: Emann0007
no shift kit yet... I'm holding the brake to stall at about 1200 rpms. Any more and it breaks loose. The car just seemed like it was horribly loose all the way through 1st. After I hit 2nd it seemed fine...
ORIGINAL: tripsevn7
I'm not an expert on auto's or anything, i've never even raced one at the track, but i'm willing to say you definatly need a higher stall to take advantage of the bfgs.
