For those with a Vortech.
What is your setup? I am trying to buy stuff I will need, specifcly what MAF? I think the Lightning 90mm sounds nice, but don't I need an adapter plate? I found one on ebay but I'm not sure if thats it. Can you guys with blowers list your supporting mods and some advice for my setup.
RE: For those with a Vortech.
monkeydude3
I dunno too much but i know that is a no. THe cobra is a DOHC and yours is a SOHC...
George
George
lucky for me a Lightning S/C will bolt right on.
heres my mod list if it may help you.....
Vortech S-trim SQ-V2 with 10lb pulley
Aftercooler for the vortech w/ IAT located after the aftercooler
4 inch homemade boost pipe
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
steeda upper and lower control arms
full length sub frame connectors
steeda caster camber plates
eibach pro springs
blu thunder short throw shifter
75mm Accufab Throttle body
C&L upper intake plenum
all synthetic oils throughout drivetrain/engine
water wetter in radiator (helps motor run cooler)
10% antifreeze/90% distilled water in aftercooler
battery relocated to trunk
Mach 1 chin spoiler
Saleen light bar
white face gauge overlay
90mm lightning maf
42lb ford injectors
310lph fuel pump
FFRP 3.73 gears
BBK LT headers
BBK catted X pipe
Borla catback
SPEC stage 2 clutch
eibach pro springs
Mach 1 chin spoiler
Saleen light bar
