fog light keeps blowing
RE: fog light keeps blowing
I had the same problem its prob the condensation in the fog light itself, will burn the bulbs. You might need to replace the Fog light Assembly. Not too much i think I got mine for $90 through FORD.
I had the exact same problem in my 03 GT. I tried different types of bulbs and always the same result. I had a couple bust within a week of installation. Turns out I had a harline leak in my fog light that let in some water when it rained or when I washed my car. The slightest bit of moisture or drop of water will cause the light to shatter when its been burning for a while. Since the car is fairly new I doubt it would have an electrical problem. Take the fog light assembly out, its not hard (3 screws), and fill it with water to see if the water leaks out. If water leaks out then you've found your problem. Put some silicone gel around all the cracks and stuff on the housing and it should solve the problem. I did this with mine about 2 months ago and haven't busted a bulb yet.
if you are looking for a nice set of clear foglights-lenses+brackets here is where I got mine for $62 shipped.
http://cgi.ebay.com/ebaymotors/FORD-...41139327QQrdZ1
ORIGINAL: SXGT
mine "blew up" too. Are there different bulbs that use less volts/watts? i would suggest that. You might have a bad ground some where.
Mine did that too. I hated it. I ended up replacing one assembly and it looks great, but then the other side did it and I tried to waterproof it by sealing it with JB Weld. I'll probably end up getting another new assembly for the other side when I get my HID kit and drilling a hole in each assembly. But obviously you can tell it was moisture.
jwog666
12-27-2021 08:09 PM
