BEST WAY TO BURN OUT WITH A 5 SPEED
RE: BEST WAY TO BURN OUT WITH A 5 SPEED
put your left foot on the clutch and your toe of your right foot on the gas and your heal of your right foot and push both in and bring out the clutch it will save the clutch in the long run
It will just keep you away from the redline. In 1st gear when you burn out, as soon as you start ,your rpm's are usually right at the redline, so when you start in 2nd gear you can burn them longer without going near the redline.---IMO
ORIGINAL: gera8712
this is new for me also. so, how about in an automatic trans. all stock , but 18x 9-10 whells???
Turn off traction control, push in the brake then push in the gas
ORIGINAL: svt_97cobra
