MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   4.6L General Discussion (https://mustangforums.com/forum/4-6l-general-discussion-88/)
-   -   Blower on...here's the dyno graph (https://mustangforums.com/forum/4-6l-general-discussion/310542-blower-on-heres-the-dyno-graph.html)
TheMustangLoveR Jun 29, 2007 12:34 PM
Well guys the blower is on. We ended up swapping pulleys to a near stock one I believe. The one already on the blower apparently was supposed to push like 12 lbs (the previous owner said 10) so the tuner told me I should swap it. Anyway, it maxed at about 7-8 lbs, and here are the results:
http://i56.photobucket.com/albums/g1...lover/dyno.jpg
What do y'all think? It's a full bolt-on car less headers, and it has a 2-core intercooler. I'm dissapointed b/c I didn't get my 400 rwhp, but then again I had to use a big pulley so I'm not surprised. Do these numbers sound about right for my set-up?
Edit: Notice the temperature while tuning/doin pulls...97 degrees!!
01Steed Jun 29, 2007 12:45 PM
RE: Blower on...here's the dyno graph
With longtubes, you could use that smaller pulley and probably be at 10 psi. Boost is all relative. The less restriction you have, the lower the boost number will be. That does not mean you'll make less power than a setup with stock exhaust manifolds and 12 psi.
Get some l/t's (and use the smaller pulley) and you'll hit that 400 mark easily.
Graph looks good. ;)
jpmustanggt Jun 29, 2007 12:54 PM
Those are pretty good numbers, with some longtubes you will be near 400.
2002GTAUTOVERT Jun 29, 2007 01:36 PM
400 is pushing the bottom end... have u upgraded your tranny?
lexy Jun 29, 2007 01:37 PM
you should be very happy with the results. Also what did you use to tune the car with?
TheMustangLoveR Jun 29, 2007 01:55 PM
No I have not upgraded my tranny...it's a 3650 and I assume it will hold for some time. But when it goes...well...time to upgrade.
My tuner tuned it via my X-Cal2
Shawn02GT Jun 29, 2007 02:00 PM
you need to look at that pulley. is it the 3.6" pulley? is the epoxy still on the pulley bolt indicating that the pulley has never been swapped?
99StangGTTN Jun 29, 2007 02:16 PM
I would put the 10lb pulley back on....
TheMustangLoveR Jun 29, 2007 02:33 PM
ORIGINAL: Shawn02GT
I'll have to look at my current pulley to see what size it is. I already know it has been swapped because the previous owner of the blower said he put a "10lb" pulley on it. Guess what? The tuner shat himself when he saw it. Why? Because it was a 2.8x"
pulley...the next to SMALLEST pulley Vortech makes. That's why it's not on there. I'll check what size my current one is though and let y'all know...I'm really curious myself lol
Ryan86272 Jun 29, 2007 04:22 PM
Good #'s ur almost to 400. Yeah my 3650 took a shytter on bolt ons(powershifted) thats why im going tko 600 soon yay!!!! g/l I have heard that these blocks are good for 450 is that correct?
© 2026 MH Sub I, LLC dba Internet Brands
