$800 install for clutch
Old 07-20-2007, 12:20 AM
scubasteve22
scubasteve22's Avatar
Default $800 install for clutch
I just called a shop and wondered how much it would be to install a spec 3 clutch and he said for that and resurface the flywheel it will be about $800. is that too much cause right now i dont have 800+almost 400 for a new clutch.
scubasteve22 is offline
Old 07-20-2007, 12:24 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: $800 install for clutch
Sounds pretty high to me, my local shop charges 85/hr for labor, that would be over 9 hours of labor (with the flywheel resurface too).
Edit: Just saw you have LTs... it might take that long. With LTs you have to remove em, install the clutch, then put em back, you can't get the clutch without taking them off.
2000GT4.6 is offline
Old 07-20-2007, 12:28 AM
Shawn02GT
Shawn02GT's Avatar
wow 800 for a clutch install is a raping, its really not that hard of a job.
get the car in the air
drain fluid
remove the drive shaft, 12mm 12 point socket
remove the shifter
remove cover over fork and remove clutch cable
remove the lower trans brace with a jack under the tranny
remove the 7 bolts holding the tranny to the engine
slide the tranny out
remove clutch and flywheel
resurface or replace flywheel, replace clutch.
torque flywheel and pressure plate to spec using lock tite on bolts.
align crank with input shaft
reinstall tranny/drive shaft etc and refill tranny
adjust clutch
Shawn02GT is offline
Old 07-20-2007, 12:29 AM
Shawn02GT
Shawn02GT's Avatar
oops i missed the LTs also
i did my clutch then LTs
Old 07-20-2007, 12:31 AM
Epinephrine186
Epinephrine186's Avatar
damn labor down here must be cheap.... i was told by a freind thats a mechanic that its a 4.5 hours job....he said he had somebody that would do it for $200 but $300 if he had to "resurface" the flywheel. but i thought labor was $65/hr at most places. and he told me that if it took a shop more than 4.5 hrs that it was bs
Epinephrine186 is offline
Old 07-20-2007, 12:34 AM
scubasteve22
yea the main reason is the LT headers he said. he has done all the work to my car so i didnt think he was tryin to rip me off but thats alot of money for an install so i didnt know but thanks and i will prob look around a little
Old 07-20-2007, 01:31 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
The headers are the issue, I've read of folks paying $400or more just to have them installed and R&R takes even longer...
cliffyk is offline
Old 07-20-2007, 07:26 AM
Ryan86272
Ryan86272's Avatar
u only have to take the pass. header off. Drive down to FLa and ill do it for 300.
Ryan86272 is offline
Old 07-21-2007, 12:10 PM
MrChubs1
MrChubs1's Avatar
ORIGINAL: Shawn02GT
drain fluid
remove the shifter
adjust clutch
QUESTION:
Normally, you gotta leave the pressure plate bolts hand tight until after you stab the gearbox back into place. This allows the clutch disc to center on the input shaft. Is this not possible on these cars? (Never done a clutch on a Mustang!)
MrChubs1 is offline
Old 07-21-2007, 12:45 PM
StealthGT2V
StealthGT2V's Avatar
That is the going rate here in NY if you have long tubes.... But with stock manifolds you can expect around $500 for install and re-surface...
StealthGT2V is offline
Quick Reply: $800 install for clutch
