Where can I get me some VHT?
Anyone know of any stores like Napa, or Autozone, that sells VHT? That sticky stuff they spray up on the field? I have two manuel hand pressure pumps that are sitting around in the house and I'm thinking of filling them up and having on hand VHT to spray incase me or another car needs the extra traction on the track.
RE: Where can I get me some VHT?
ORIGINAL: JD1969
Your track lets you spray your own VHT? I have never seen a track do that.
ORIGINAL: contentsunderpressur
Hahaha, if you want VHT at our track you have to bring it yourself. We put it in coke bottles and punch a small hole in the cap. The first run it works great but the traction seems to dye down the more you run. I'll ask my buddie where he gets it and if someone hasn't given you an answer by tonight I'll let you know.
ORIGINAL: JD1969
Coolies! Thanks!
Also if you can ask, is it in a powder form and he has to mix it up with water? Or is it already pre-mixed liquid?
Ok I'll ask. I'm pretty sure it was already in the liquid form. It come in a one gallon jug. Smells great too.lol
ORIGINAL: mylongvictor
Coolies! Thanks!
ORIGINAL: JD1969
Coolies! Thanks!
Liquid Gallon jug...
ORIGINAL: 8banger
Jegs sells it ,,,,but you dont have any local speed shops around?You dont have to spray it on the tires @ the track...it also restores old worn tires that have lost they stickyness.....I had old set of goodyears 33x16x15 and coated them with a roller 3 coats let dry inbetween in the sun..wait 24 hours to run....soaks right in and makes them sticky!!!!!@ the track....I went from high 1.20's 60 to a 1.15 the next week....
Coolies! Thanks!
ORIGINAL: JD1969
Coolies! Thanks!
Wow... never mind.... I found it....
http://www.jegs.com/webapp/wcs/store...10002_51620_-1
