Clutch advice please.....
RE: Clutch advice please.....
ORIGINAL: ripped camel
I'm supposed to have my Fidanza aluminum flywheel (which I've already purchased) & a FRPP clutch (which I'm buying from the shop) installed tomorrow. Problem is I have an 03 GT and the FRPP on every site says it's a 10.5" disk. I've read many places my car has an 11" plate. So here's the problem.
The guy told me that he won't know if it'll work till he gets the tranny apart. If it doesn't fit right he said I'll have to order another clutch. I don't want to order the Spec stage 1 as I've heard way to many horror stories for my liking. I'm one of those that always ends up being the worst case scenario, so I don't want to take my chances with it.
I'm also not looking to spend $300+ for a clutch. I don't have enough to cover that. So I've narrowed it down to a few options but don't know which way to lean. Some help would be greatly appreciated.
Mcleod clutch.....
http://www.steeda.com/products/clutc...sure_plate.php
Ram stage 1clutch......
http://www.rpmoutlet.com/musv8ram.htm
Steeda clutch kit.........
http://www.steeda.com/products/steed...e_clutches.php
Mods are in my sig. I don't plan on ever adding a power adder. will eventually do minor thing like typhoon intake mani, accufab plenum & tb, SCT X2 & 3.73's. That's about it.
If anyone has had experience with any of these post up. If you personally know someone that had any experience with any of these post that up too. Thanks.
Mcleod clutch.....
... Just giving you a heads up. They're bad to do business with.
But to add a little to what 2000GT4.6 is saying, you'll hear a lot of mixed reviews with Spec. The majority of Spec owners love their clutches (especially the Spec 3). But there's also the select few that have had bad experiences with them, and would never put another one in their car or recommend one to someone else.
Now about your options, I'd say give the Ram a try. Just be sure your order it from someone else.People whohave Ram clutches seem to be really happy with them.
Not to steal your post my man, but could someone explain to me why you wouldn't prefer a light weight flywheel over stock, and to add to that, why a light weight flywheel is not recommended for daily driving? Also, how much is a clutch install usually and..
what does a ..
do for me? My drivetrain knowledge of the Mustang isn't up to par. But that's what you guys are for.
what does a ..
steeda 3pc adjuster kit. Well worth the $99.00
Okay so I ended up going with some clutch called valejo or something like that. I found out that a few companies outsource clutches and all are using that same exact clutch. The guy I talked to when I was at the shop says that's what he's installed on a few terminator mustangs, so if it's good enough for that car, my car should run fine on it.
As for the aluminum flywheel. I'll post up how it drives after the install.
steeda 3pc adjuster kit. Well worth the $99.00 do for me?
Well my Spec Stage I is in for at $341.32 for labor, $90 over what I was quoted but that is understandable since they said they had problems with that one bell housing bolt near the starter.
Ask for adjusting the clutch with the stock quadrant, what the manual says doesn't work most of the time especially if your clutch cable is getting a little worn. Either reach down there and adjust the quadrant with your hands. Or if you can't get under there if you push the clutch all the way down and then slip your foot off quickly and let the pedal pop out that will usually force the ratcheting mechanism to adjust.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
