Transmission!!!Question
Hey guys i haven't been on here in a where.I'm getting a divorce and I'm only 25 but been marriage for 5 years.Enough talking about that.So i think i have the T-45 and it finally took a crap on me and i forget what all u need to change over to a 3650 tranny or i mite buy a brand new t-45 if i can find a good price and still use my atfermarket shifter that i like.So any idea's guys and i dont have the money for a tko any more.Looking for $1000-$1200 or under
RE: Transmission!!!Question
Are they the same spline and can u use the 10.5 clutch with the 3650.
they are both 10 spline. As long as you use a 10 spline clutch you will be fine. I'm not sure about the plugs on the transmission, or the transmission mount, but those might be some issues you want to look into.
What is wrong with your transmission? |
the 3650 uses 11" clutch and flywheel and both are 10 spline
DO you have any good performance transmission shops around? T-45's can be built to handle quite a bit. And it's a cheap alternative to buying a new "whatever"
