clutch adjustment
clutch adjustment
is there any way to adjust my clutch with the stock cable, or do i need to get an aftermarket adjustable cable, like the Steeda? i've also seen firewall adjusters, can i use one of those with my stock cable, or would it be best to use it with the aftermarket cable?
RE: clutch adjustment
The stock quadrant and "semi-automatic" adjuster is the fundamental cause of the problem. Get an after market quadrant and firewall adjuster and keep the stock cable (which is superior to most aftermarket adjustable cables I've seen).[/align][/align]I have UPR's triplehook quadrant andQuick Click adjuster--they would have been one of my first mods if I had realised how much better the clutch would feel by getting rid of the plastic OEM junk...[/align]
is it really that big of diffrence????? im getting a spec stage 1 clutch and a steeda quadrent,firewall adjuster and cable. ive all ways hated the feel of the pedal. before any body says get a stage 2 of anything else i am on a budget and the spec stage one is rated at like 350 hp and 400 ftlbs tq. ill never reach that hp level anytime soon. i cant wait!!
ORIGINAL: cliffyk
im not sure, but if the 4.6 quadrant is like the old foxbody ones then yes with a spec stage 1 id change it
i threw a spec stage 1 in my 88gt and a few weeks later i killed the stock quadrant
again, not sure if these ones are the same as the old 5.0s though but it sounds like they are
ORIGINAL: dimebag
junior04
09-28-2015 10:53 AM
