h-pipe newbie question
RE: h-pipe newbie question
got an 02 GT.
i will be getting the tuner, 4:10s, and h pipe. kinda want to do them all at one time. i really dont think ill have any issues with this.
i will search for that sender.
thanks for the help on the h pipe, will check out the videos now!!
any other good ideas.......are the underdrive pullies a noticable help?
oh, how do i get emails when i get replies...i think i set my profile up correctly!
b70
b70
always liked the zombie, black sunshine tune! great quote!
if i have the tuner and install the hpipe, can i just remove the o2 sensors and plug the holes?
the tuner will eliminate them from the system by computer so i would assume that theyre not needed at all. unless of course i wire them to my LM1, any thoughts?
will you notice a hp gain with udp's? yes!
as far as 02's and the tuner. you can turn the rear 02's off (those are the ones that trigger the cel)but leave the 02's in there to fill the holes in the pipe.
order your tuner from brenspeed.com
they are the number one sct tuner in the united states.....you provide them with your mods and sutch and they write you the tunes and send them on the tuner.
ORIGINAL: MoKo_04GT
+10 on Brenspeed
great guys working there
boatn70- your oil pressure sending unit, before buying it you might see if it is getting voltage with a multimeter if it is it could be at the actual gauge itself, my fuel gauge had a loose connection there which saved me from dropping the fuel tank.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
09-24-2015 09:18 PM
