stall when brake is pressed
need some diagonises help. this happens sometimes but not all the time. when im coming to a stop i take it out of gear and press on the brake and the rpms will drop. if i press on the brake harder the rpms will drop more. and sometimes it will stall. my normal idle is around 700 when out of gear and on the brake with a soft foot it drops to about 500 if i press harder it will drop to about 300 then it will go back up with foot still on the brake im thinking iac but not 100% convinced yet. some opions would be great. thanks in advanced
RE: stall when brake is pressed
more than likely the powersteering pump is creating too much load on the motor. i would say it is due to a dirty or faulty IAC because the computer should be able to adjust the counts to keep it idling.
off subject but livefast what cage is that in your car is the mm 6 point???? back on subject it is the original iac with about 99k on it. i just want to be sure before i spend money on a part i might not need
its an S and W 8 point i got it for around 176 i believe. and i would try taking the original one off first and cleaning it good with carb cleaner as with 99 thousand miles you will probably find a good bit of carbon in it.
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
