new trick flow intake manifold
#41
RE: new trick flow intake manifold
The valve covers are moroso and bought from rpmoutlet.com. If you get them you have to have them drilled for a PCV system.
1sloblckgt, That is a good intake but I would not recommend the edelbrock elbow. That elbow is designed to clear the stock hood and not for performance. Go to mod ularfo rds. co m and there is plenty of info on that intake and the different plenums. Take the spaces out of course
#42
also with this i have noticed that have a wierd idol is that stillmean i need to get the ecu use to the new intake i am planning on leaving the negative off alnight if that will help it
#44
If you have an idle problem that means bad install. Vacum leak.
The bullitt intake is complete garbage compared to the trickflow. People like to compare them but they are nothing alike. The only thing that is similar between the two is the fact that the plenum comes from the back and over the top. You will be lucky to gain 5hp with a bullitt and could gain 10hp easy on a bad day.
#46
ORIGINAL: lizzyfan
Yep, and you will too
ORIGINAL: 1sloblckgt
? You had to drill one in your PI manifold?
#47
looks clean, but i think you should get a diffrent filter for the end. i hate the big black round intake container thing. i'd look better with a jlt or k&n set up
#49
Just get some propane and check for leaks. There are plenty of places that they could have messed up during install. Bottom cover, plenum, TB, vacum ports, anything could be leaking.
jwog666
12-27-2021 08:09 PM
