hood cutting
hood cutting
how would i go about safely cutting my fiberglass hood? i want to cut the section behind the cowl out and add a mesh to make it a heat extractor hood, i hate having a big hood that does aboslutely nothing for me, tons of ricer comments being made lol
(i didnt buy my hood, it came on the car when i bought it)
RE: hood cutting
i did this on a v6 hood, you need a very very small spinning blade (home depot sells kits like these) and just go bit by bit, make all the marks before hand, itll make a HUGE mess of white powder. you can use a sawsall or dye grinder but those are a thick cut and make BIG cuts..
otherwise should work out OK and home depot or a hardware store has mesh wires you can pick out from and attach to the hood =D
good luck
good luck
RE: hood cutting
ORIGINAL: 99BlackPonyGT
I used a Dremel tool with a heavy duty cut off wheel and a jig saw with fine blade blade to cut my stock hood for my CDC Shaker kit.
Lynn
RE: hood cutting
RE: hood cutting
No, thats way to big... that will cause cracks in the hood or produce way to much heat... like this
http://www.minicrafttools.com/kits.html
very bottom, use the carbon blade.
i have a similar kit but mine is HUGE and has about 100 different bits, for hood cutting you just need the carbon blade (its seriously no bigger then 3" across) and the sanding bit to fix the edges after you do your cutting
send me a PM with your email address and ill send you some before and after pics on a hood i worked on
RE: hood cutting
PM me the pics
and i like the hood, its not going anywhere lol
i photoshopped a rice bowl onto my car and posted it and said **** off (local forum), i really dont care lol just figure that if i have such a big hood, i might as well do something with it
