Dome light staying on
Not sure why my dome light will stay on forever. I had to take the bulb out because it was really annoying when i was driving at night. It's also annooying that when i turn off the car the little chime will keep playing over and over. Any ideas?
RE: Dome light staying on
Hardtop or Vert?
Find the light green w/ yellow wire and follow it to and check for power along the key points; your alarm or keyless entry. Check at Fuse #8 (30amp) wired to the HD LPS Fuse (blk/Org). |
ORIGINAL: sxynerd Hardtop or Vert? Find the light green w/ yellow wire and follow it to and check for power along the key points; your alarm or keyless entry. Check at Fuse #8 (30amp) wired to the HD LPS Fuse (blk/Org). |
ORIGINAL: art02gt ORIGINAL: sxynerd Hardtop or Vert? Find the light green w/ yellow wire and follow it to and check for power along the key points; your alarm or keyless entry. Check at Fuse #8 (30amp) wired to the HD LPS Fuse (blk/Org). |
ORIGINAL: 2000AZ5.0GT ORIGINAL: art02gt ORIGINAL: sxynerd Hardtop or Vert? Find the light green w/ yellow wire and follow it to and check for power along the key points; your alarm or keyless entry. Check at Fuse #8 (30amp) wired to the HD LPS Fuse (blk/Org). |
He's saying you might have it set all the way in one direction to the point where it turns on the interior lights...and leaves them on. I've been there, done that.[:@]
ORIGINAL: art02gt ORIGINAL: 2000AZ5.0GT ORIGINAL: art02gt ORIGINAL: sxynerd Hardtop or Vert? Find the light green w/ yellow wire and follow it to and check for power along the key points; your alarm or keyless entry. Check at Fuse #8 (30amp) wired to the HD LPS Fuse (blk/Org). |
ORIGINAL: 99GTvert He's saying you might have it set all the way in one direction to the point where it turns on the interior lights...and leaves them on. I've been there, done that.[:@] the problem is it doesn't allow the alarm to fully engage, so it's alot easier to break into the car when the lights are like that. |
Trace the wire to it's switches and fuses and find out where the closed circuit is. Two mail places would be the switch ^ that they are talking about and if you have an alarm with courtesy light supervision.
ORIGINAL: 2000AZ5.0GT ORIGINAL: art02gt ORIGINAL: 2000AZ5.0GT ORIGINAL: art02gt ORIGINAL: sxynerd Hardtop or Vert? Find the light green w/ yellow wire and follow it to and check for power along the key points; your alarm or keyless entry. Check at Fuse #8 (30amp) wired to the HD LPS Fuse (blk/Org). |
