yes it should work on your car and no you can't use the plenum as it uses a different style upper plenum to attach the throttle body. i would be worried about the price as most go for 5-700 bux i believe.
is the plenum in the same spot because i dont want to buy a new intake tube from the blower to the tb. and would that intake gain any hp or is it not worth it?
the tb is not in the same position. the position of the bullitt intake is much like the trickflow track heat if im not mistaken. so you would have to buy/modify the one that is currently on the car.
should gain you a few ponies on a blower car as i believe they flow a good bit better in the upper rpms. the throttle body is close but i believe it uses a twin blade oval inlet setup.
