Thats what I'm thinking, sell that stuff and buy these, Will an aftermarket manifold buy me anything or is the PI upgrade good enough ( I already have a new one)
Depending on what your future mods are, i would go ahead and probably buy a different manifold for it cus the stock ones are prone to crack on some applications like boost or nitrous. So i would just go with something like the trickflow track heat or a p51 or something. Summit has the track heat with twin 57mm throttle body and thats good for more airflow and higher rpm power. Thats just what i suggest you to do just to be safe.
Trick Flow heads, stage II cams and intake and you will be pushing around the 410-420 flywheel HP mark, if not a little more. All this for less than $3500.
