headlights not working....this is rediculous
Old 02-02-2009, 12:40 PM
kadoi
kadoi's Avatar
Originally Posted by WhiteFoxGT
the RD/YE wire comes FROM the main switch to the multi function... And it should be hot when you turn the switch to low beam
okay well its definately not hot when i turn the headlight switch, so this rules out the multifunction switch because power would not even be getting to it yet in order for it to even have a problem. WhitefoxGt thanks so much for the help been a real life saver so far. One more question, what could cause the red/yel wire to be dead at the headlight switch in the on position?
kadoi is offline
Old 02-02-2009, 12:41 PM
kadoi
kadoi's Avatar
plus none of the headlight fuses are getting power in the fusebox but the main one under the hood does have power.
kadoi is offline
Old 02-02-2009, 02:53 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
So the main switch has power goin into it, but no power coming out? The RD/YE wire comes from the main switch to the multifunction, and if you have no power at the multifunction correct? Chekc for power coming out of the main... Are you sure the switch is correct?
WhiteFoxGT is offline
StalkerGT
11-28-2015 03:09 PM
Seanam
10-04-2015 10:15 AM
Drastang
09-29-2015 03:31 PM
Mobiusone stang
09-07-2015 08:46 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: headlights not working....this is rediculous
