Supercharging a 1996 4.6 mustang
Hi, I'm evaluating to install a supercharger to my Mustang.
I was offered a used one, could anybody tell me what should I check on the supercharger before installation or what should be replaced?
I'm also plan to change the clutch. Should I take care about any other part in order to handle the extra power (transmission, etc)?
Thanks,
Thanks,
Thanks,
Thanks,
the motor will blow before the tranny/rear
As far as the rear is concerned it just depends on what kind of launches he is doing with that power and using sticky tires. Also, the tranny is only rated for 325ft/lb...
t45s usually hold up to more than 325ft/lb ... theres plenty of members here with blown gts using the stock tranny...at the same time, that also depends how you drive...i could put my car is second gear and dump the clutch at 6k... im sure ide manage to break a lot of stuff and its mostly stock lol
