best transmission fluid?
Old 03-10-2009, 10:19 PM
02stangdude
02stangdude's Avatar
Default best transmission fluid?
just bought a rebuilt tremec 3650 for my 02 gt and was just wonderin what is the best transmission fluid to put in it. also does any one know how much goes in these transmissions or where i could find out?
02stangdude is offline
Old 03-10-2009, 11:32 PM
Tazzy
I use royal purple, 3.1 qts
Tazzy is offline
Old 03-11-2009, 09:03 AM
OzzDOA
Gah! Do not put a synthetic into these transmissions. Use 3.2 quarts of either Dexron III/Mercon or Pennzoil(GM) Synchromesh. Sythetics will chew the synchros.
OzzDOA is offline
Old 03-11-2009, 09:07 AM
Fobra
Banned
Just use what TREMEC says to use and dont try to re-invent the wheel - Dex/Merc III
Fobra is offline
Old 03-11-2009, 05:37 PM
JayC
Synthetic is fine and has some real advantages and will not hurt your syncros.
JayC is offline
Old 03-11-2009, 06:06 PM
jwarner0297
jwarner0297's Avatar
Everyone has this idea??? where did it come from??
not the tremec manual. Synthetics will be fine in the trans.
OP- mobil 1 syn. ATF with 3.2 qts
jwarner0297 is offline
Old 03-11-2009, 06:21 PM
02stangdude
ooook thanks guys
Old 04-30-2009, 05:29 PM
AmericanPowertrain
Former Sponsor
Default Weighing in on fluid choices
Dexron (there is no "t") is fine for the 3650, however I prefer either GM Synchromesh or Royal Purple Synchromax. These fluids hold up better when beaten and their sling rate is better for synchronization. While synthetics do not hurt the transmission per se, you will generally have to stay with it forever. Synthetics tend to swell your seals, which means if you keep them in the gear box long enough and then go back to natural fluid the seals can shrink and fail. Basically, once you go with a synthetic fluid, stay with it. I have seen plenty of gear boxes with 30,000 miles on Synchromesh and it comes out almost as clean as it went in. I don't really know if the extra $$ for full synthetics net you much in performance or clean running. Just my 2 cents.
[email protected]
AmericanPowertrain is offline
Old 04-30-2009, 08:56 PM
Fobra
Banned
Fobra is offline
jwog666
01-07-2018 07:16 AM
Thunderball
15
11-22-2015 11:49 PM
wraith777
09-28-2015 10:49 AM
09-25-2015 06:42 PM
Quick Reply: best transmission fluid?
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
