Tuning Advice --Cliffy Welcome :)
Ok, here is my issue. I am about to add Bassani Mid-Length Headers and with my mods listed below I think it will be time for a tune. I am pretty convinced that Sniper is the way I am going. Here is the issue. I am aggresively looking for a SuperCharger and when I find a good deal I will pull the trigger, I plan on having it supercharged by the end of next year. So should I just buy the commando or when they do a dyno tune will that not be transferable to the Sniper software? I think I can find a good deal on SF and really didn't want to drop 600+ on commando if I don't have to seeing that the Headers just set me back like 600 and they aren't even installed yet. Thanks All
You first need to decide if you are going to be tuning the car yourself, or paying someone else.
If you have a supercharger installed and in the process "they do a dyno tune", and said dyno tune does not included a tuning device (I.e. "they" just flash a tune and you drive off), then you will be pretty much married to that tuning shop or another using the same system (likely to be SCT unless you find a Delta Force shop).
If you get the dyno tune and a tuning device (so that you might further tweak the tune and/or restore the OEM tune). Then it would be possible to capture the "foreign" custome tune with Commando or Delta Force.
This is a somewhat complex process that requires capturing the foreign tune with the Delta Force Interface (using a bullet), saving that tune to your PC (and renaming and moving it), and then reflashing the foreign tune from the DFI back to the car which gets your bullet back.
You would next use the non-Delta Force tool you cam home from the dyno shop with the flash the OEM tune to that car, and then use the DFI to get the stock tune and recognise you PCM. The "foreign" tune can then be treated as any other Commando tune, modified and reloaded as you wish.
There is a step-by-step process for doing this on the DF Forum (in that case a bit more complicated because the OP had already loaded a Commando tune).
I would have bought Commando before I bought the headers...
Ok, that was kind of what I was looking for. I know the tuning shop where I have my work done is Sniper friendly. Here are my concerns. I will most likely not be supercharging until next year, even if I find the hardware this year. The shop I go to has a dyno and if they install my supercharger I would get a dyno tune while I am there. If I brought my Commando software they would basically use my bullet and Commando to do the dyno tune correct? I just want to be able to have the tune in case the shop or the guy go MIA. Also, I realize that I am not getting the most out of my mods with out a tune but do you think at this point with my listed mods I need a tune? Thanks Cliffy!
well you should already have a tune to correct your speedo from the gears...and if your car is an auto, you would probably feel a good deal from the tune with your shifts and stuff like that. So I would go ahead and get a dyno tune now because it shouldnt be all that expensive for an N/A car to get a tune for it not being all that involved. So go for a tune after you put the headers on.
Luke9222
10-22-2015 11:55 PM
panic
09-10-2015 05:56 PM
09-08-2015 06:25 PM
