replacing rear speaker
+1 to the six pack
Lift up the rear seat a bit in the front. This will expose two white pins in the middle on both sides that hold the rear seat in place. Press them in and pull the seat up and out.
The back top portion of the rear seat has two bolt on the bottom and a hanger on top. remove the bolts and pull the top rear seat out.
The side panels are held in place by pull pins, remove the pins and carefully remove each side panel. I also believe there are a couple screws so if the panel doesnt come off easily check for screws.
Then you will see the speaker and its enclosure, and there are 4 torx screws holding the speaker in.
Mustang Sally72
08-11-2015 07:54 AM
