HID box location
HID box location
Were did everyone mount the box for there headlight hid's i cant find a good place for the life of me i would search but is not the easiest to do on my itouch thanks in advance
i mounted my driver's side between the battery and the fenderwell, and the passenger's side on the flat part under where the stock air filter would be. My old GT i took the plastic radiator support cover off and mounted the ballasts right under that. so if you're lookin at the grille, 1 was to the left, 1 to the right. but you couldnt see em from the outside. Anyways if each ballast has a ground, use your headlight ground.
Yeah use a real small flat head screw driver. You have to swap the lo beam and ground wires. if i remember correctly. Just use a multimeter and test the voltages on HI vs. LO. You'll be able to figure out which 1 is the LO.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
