Rear end?
Clutches
A rebuild kit that you will need
31 spline differential, you will not need the trac-loc rebuild if you buy a new differential.
31 spline axles
Your also going to have to get a Speedcal to correct your speedometer for your new gears.
31 spline axles
K thanks so much great help
one more thing about gears should i go 3:73 or 3:90?
and when you buy axles from am do they come in sets of 2?
and do I need a 8.8 diff cover or will the stock one work?
i would recommend a new diff cover... they are only 130, and the stock one is junk
my car is 11 yrs old and 160k miles, and the rear end has been blown up atleast once...my diff cover still holds fine, no leaking or anything
