Rear end?
#21
will this be ok?
****edit, i posted this in the wrong thread....meant to post it in the one i made...but i guess its relevant, so ill leave it here
this is the setup i may be switching to...depends if it can hold up or not
i may spend a few hundred more and go with a 35 spline 9"
#22
If you're looking for a decent 31 spline differential, I would look here
http://www.buyfordracing.com/shop/pr...=543cPath=3_37
Cheapest place I've found gears would be the same place....
http://www.buyfordracing.com/shop/pr...=459cPath=3_37
You will need an installation kit with the gears too. That website has them but I've found the install kit for about $70 on summit racing.
#23
That looks good, I can't figure out how to do that with Vista. I could do it with XP........
Anyways, as far as the diff. cover, if your on a budget and yours is in good condition, then you dont need one.
Do they help? Yes.
Are they more for a high horsepower car that actually has to worry about pushing the main caps? Yes.
Do they help? Yes.
#24
Do they help? Yes.
Do they help? Yes.
Dragonus18
09-09-2015 01:21 AM
