Rear Tires...
Old 04-29-2009, 11:02 AM
04CompetitionOrange
04CompetitionOrange's Avatar
Default Rear Tires...
I posted this in the wheels and tires section, but it doesn't seem to get much traffic:
I am looking at a pair of used pirelli's for my rear wheels. Here is a picture of the tires...I am a bit confused about the curved blocks down the center. Can both of these tires be mounted on the rear wheels or are they two right hand / left hand tires that are being sold as a set? I don't want to buy two 285's if they are meant to run on the same side.
04CompetitionOrange is offline
Old 04-29-2009, 11:22 AM
99 GT vert
99 GT vert's Avatar
those tires are a symmetrical which means one side is ment to go towards the out side and the other side goes inwards they can be used on either side of the car
99 GT vert is offline
Old 04-29-2009, 11:33 AM
04CompetitionOrange
So if I understand the explanation correctly, they can both be run on the rear wheels at the same time...and since they are asymmetrical, it doesn't matter which side either tire gets mounted on....correct? Thanks for the help.
Old 04-29-2009, 11:34 AM
pikuoff
pikuoff's Avatar
Just make sure they mount them correctly on the rims to go on each side of the car.
pikuoff is offline
Old 04-29-2009, 11:57 AM
99 GT vert
99 GT vert's Avatar
yes the tires should have marks to which side is out and which side goes in
Old 04-29-2009, 02:09 PM
sweger
sweger's Avatar
those look like a much worn down version of these PZero Rosso 'asimmetrico' tires. looks like they can both be run on that back no problems.
sweger is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
09-30-2015 10:13 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: Rear Tires...
