rear end options
#31
if i was gonna build a rear to go 9s and was my daily driver or did ALOT of street driving i would go 35 spline stranges if they make them, e locker, c clip elims, weld the tubes, brace the axles with some roll bar tubing, girdle, gonna have to upgrade to some stronger material gears. if it doesn't see as much street duty cant beat a spool. the e locker basically is has a field coil from my understanding, when you flick the switch the mechanism inside the diff locks the axles together and when switched off it unlocks them and acts as an lsd. with the option of an e locker i don't see the point of an air locker as you don't need the air supply with an e locker.
#32
ok i found 33 spline stuff thats custom order from jegs...
http://www.jegs.com/i/Strange+Engine...00FM/10002/-1#
in the desc. it says
# Pro Race 33-Spline Axle PackageFits with 8.8" Ford housing ends.
# Incl Spool, C-clip elim's & 1/2" wheel studs
# Special order item. Please use the Custom Axle Order Form or call customer care for ordering info
1-800-345-4545
so it includes a carrier or am i missing something?
1-800-345-4545
#33
#34
what about gears...you said i would need a stronger material...ive never seen the option of one material over another...
#35
that should be a pretty strong setup. like i said you can't beat a spool for strength.
#36
http://www.americanmuscle.com/gms-79...le-system.html
http://www.jegs.com/i/Ford+Racing/39...33-G1/10002/-1
and are you sure that axle package has axles and a carrier? i feel like im reading it wrong... because $650 or whatever is cheaper than getting the 31 spline moser axles and the eaton setup...i feel like $650 is too cheap to be the axles and carrier
#37
i wouldn't let gms wash my socks, so the ford racing one. i would also consider the one jegs offers as well i believe its like an ultimate girdle or something, comes with weld on tabs for the axle tubes and you run a piece of tubing from the cover to the tubes to brace the backside of the tubes to the pumpkin. then run some rollbar tubing from the front of the tubes to where the dogbone bolts in place and you should be all set bracing wise (you want to eliminate the tires from walking away from the pumpkin on launch).
#38
http://www.jegs.com/webapp/wcs/store...10671_-1_10149
all they show cover wise is a chrome one...
and you sure about that axle package? why is it so cheap?
#39
ok...this one?
http://www.jegs.com/i/L.P.W./619/101-8.8/10002/-1
with this?
http://www.jegs.com/p/L.P.W./744457/10002/-1
with this?
#40
http://www.jegs.com/webapp/wcs/store...11341_-1_10049
my bad its the lpw stuff, the cover and the tie bar kit above it. i would feel more comfortable with a set of strange 33 spline axles compared to the ones in that kit but that would be your call.
